8" or 9"
Old Oct 10, 2006 | 02:32 PM
jarrettdad's Avatar
jarrettdad
Default RE: 8" or 9"
It should be an 8".... but then again mine shoulda been a 9"...
From the rear if the housing is more oval than circular it is an 8". 9's are more circular.
Old Oct 10, 2006 | 06:31 PM
THUMPIN455's Avatar
THUMPIN455
I just look at the bolts infront.. Simple rule with them.
Old Oct 15, 2006 | 09:08 PM
ebluekeys's Avatar
ebluekeys
Most of the mustangs came with 8 inch, except for the HIPO models which had 9's. If you crawl under the car with a piece of paper, just rub the paper up against the casting where the ID numbers are. Usually, it's so darn dirty, you can't read it, and it's in place that's hard to see as well. The paper trick works pretty good - give it a try. Just press it up against the numbers and rub. Then look at the paper. Beats getting a neck strain and grease in your hair under the car!!
Old Oct 15, 2006 | 11:13 PM
ultrastang's Avatar
ultrastang
A simple way to tell an 8-inch from a 9-inch is to see if you can get a 9/16" socket onto the bottom most studs of the 3rd member-to-housing studs to remove the nuts.
If you can get a socket on them, you have an 8-inch. If you can only get a 9/16" boxed-in wrench on them, then you have a 9-inch.
http://ultrastang.com/Rearinfo.asp?Page_ID=1
www.ultrastang.com
Old Oct 15, 2006 | 11:40 PM
Decurion's Avatar
Decurion
so would an 8" centersection fit in a 9" housing? or is there even any difference in the housing?
Old Oct 16, 2006 | 03:13 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Nope...not even close. The housings are different.
ORIGINAL: Decurion
