Fuel Pump
Old Oct 12, 2006 | 08:22 PM
rcdblink716's Avatar
rcdblink716
Default Fuel Pump
Building a 347 for my stang. 11:1 compression, track heat heads, parker intake, and a few other goodies. Going carbureted witha 750 speed demon. Can I run a mechanical Pump? If so which do u suggest? Do i need a regulator? Your input is greatly appreciated.
Old Oct 12, 2006 | 09:18 PM
Gun Jam's Avatar
Gun Jam
Default RE: Fuel Pump
I would think so
The carter high volume with good lines that dont have any sharp bends or kinks
should work if your HP is less than 500.
No reg is needed, its gonna be close but i think it should work
Gun
Old Oct 12, 2006 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: rcdblink716
I have never liked electric fuel pumps, mainly because of the noise they make. Try checking out the racing mechanical pumps. Here is the edelbrock Performer mechanical fuel pump that is advertised to handle up to 550 ponies.
http://www.mustangsplus.com/Merchant...Code=fuel_pump
Old Oct 12, 2006 | 09:32 PM
rcdblink716
Thanks guys. Ya'll are a big help as usual
Old Oct 13, 2006 | 01:27 AM
mustanglover66's Avatar
mustanglover66
Mechanical pump should be fine but you may whant to rethink that 750 demon, we build a 347 with a blower pushing 530 hp and over 500 ftlbs of torque with a 650 db pump holley
Old Oct 13, 2006 | 01:35 AM
andrewmp6's Avatar
andrewmp6
you can but i like the electric pumps higher flow
Old Oct 13, 2006 | 02:06 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
be sure to use a good pressure reg
Old Oct 13, 2006 | 02:36 AM
Gun Jam's Avatar
Gun Jam
It doesnt have to be higher flow if it flows enough.
The electric pump causes a whole bunch of new problems:
1) a reg to fail
2) more pressure = more chance to create a leak
3)electric motor to fail
4) if a float sticks and the engine dies the pump keeps on keepn' on
5) greater fire risk
The electric stuff probably wont give you any problems but be aware that it IS MORE prone to serious problems as well as minor ones vs a mechanical pump. my buddy put one on his firebird and now it sits because the reg failed.
Stick with a mechanical one if possible.
Gun
Old Oct 13, 2006 | 04:25 AM
andrewmp6's Avatar
andrewmp6
i have broke a mechanical pump on the 65 impala i had only problems i seen with a electirc pump was installed wrong
Old Oct 13, 2006 | 04:45 AM
Brandontyler65
I ♥ Acer
well i would do what ever you want just remember this if your elec pump does die you can go to a nearby auto part store and get a stock to limp home on well maybe if you carried some hose and a wrench and what not you could do it either way
