Fuel Pump
Old Oct 13, 2006 | 05:18 AM
65mojoe's Avatar
65mojoe
Default RE: Fuel Pump
A mech. pump is fine and with that build, you would be fine with a flow of around 110gph (thats usually good to about 500hp). There are tons of aftermarket pumps with this rating: Holley, Edelbrock....Just do a search through summit.
And +1 rethinking the carb cfm size. I think you'll be overcarbed with a 750....go for the 650 double pumper or anything below 700cfm.
Old Oct 13, 2006 | 03:02 PM
rcdblink716's Avatar
rcdblink716
What do ya'll think about a 650 speed demon w/ vacuum secondaries? Thanks for the advice guys
Old Oct 13, 2006 | 03:04 PM
rcdblink716
do i need a regulator for the mechanical?
Old Oct 13, 2006 | 03:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Mechanicals don't need a regulator.
Old Oct 13, 2006 | 03:12 PM
rcdblink716
thanks man
Old Oct 13, 2006 | 03:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
The needle and float regulate how much fuel the engine needs.
Old Oct 13, 2006 | 03:26 PM
rcdblink716
so what do u think about the 650? right size for set up?
Old Oct 13, 2006 | 08:40 PM
65mojoe's Avatar
65mojoe
650 or 670 should flow about right, and ya you dont need a reg. for the mech. pumps
Old Oct 13, 2006 | 08:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, for your setup, the 650 will be just about right. After you get her on the road and drive it for several hundred miles, you will be able tol tell if it is perfect or not. Good luck with it.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
