Help, Rusted Bolt
Old Oct 13, 2006 | 12:36 AM
PReal's Avatar
PReal
Default Help, Rusted Bolt
What should I do about this bolt???
My vice grips broke it off at the water pump and I had to pry the timing cover off.
BTW this is what happens when your friend has a sand blaster at work.
Old Oct 13, 2006 | 12:40 AM
baddog671's Avatar
baddog671
Default RE: Help, Rusted Bolt
Looks like your f'd now. Have fun!
Old Oct 13, 2006 | 12:43 AM
rcdblink716's Avatar
rcdblink716
Might have to cut it off, center punch it, drill it and re-tap it
Old Oct 13, 2006 | 12:45 AM
burnettt's Avatar
burnettt
try to drill a hole through the bolt so u can stick something through it and possibly turn it, or use a cutting wheel and cut it off flush with the block then drill it out and hopefully use a tap and dye set set to clean up the threads.
Old Oct 13, 2006 | 12:46 AM
burnettt's Avatar
burnettt
dammit rcdblink716 ya beat me to it.
Old Oct 13, 2006 | 01:20 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
did the other one break off also
Old Oct 13, 2006 | 01:52 AM
Calixtus's Avatar
Calixtus
If you think there is a remote possibility of turning it, you could try to file/grind flats on it so you can grab it with a wrench. (Plug that hole first with a rag or something. You want to keep it clean in there ) The closer to the hole the better, to minimize bending forces. Might be worth a shot, and if it snaps again lower down you can still cut it and drill it out.
Old Oct 13, 2006 | 02:05 AM
Sean W.'s Avatar
Sean W.
so thats waht a timing chain looks like..... kewl.
those sandblasted barts are sweet. look brand new.
Old Oct 13, 2006 | 02:10 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
i would get wd 40 soak it for a day and heat it up and tap with hammer it might break loose
Old Oct 13, 2006 | 02:15 AM
mustanglover66's Avatar
mustanglover66
Don't cut it off at the block if you don't need to thouse bolts are case harded and are just about impossible to drill, get a torch and heat it to red hot and use the vise grips.
