Help, Rusted Bolt
Old Oct 13, 2006 | 04:42 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Help, Rusted Bolt
thats what i said
Old Oct 13, 2006 | 10:35 AM
PReal's Avatar
PReal
I don't have a torch. Should I go buy one of those little propane ones.
Old Oct 13, 2006 | 10:40 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah good investment when it comes to taking apart a 40year old car
Old Oct 13, 2006 | 11:29 AM
PReal's Avatar
PReal
I talking about the little one that looks like a lighter.
Do I need a larger one?
Old Oct 13, 2006 | 03:03 PM
67Stang68's Avatar
67Stang68
Maybe a little oxy acetalyene setup , I dont think propane would be hot enough
Old Oct 14, 2006 | 10:57 PM
deadcarnahans's Avatar
deadcarnahans
Soak it, heat it, soak it, heat it, weld a socket onto the end of it and vibrate it while you turn it. Heat the block before you try to turn it.
What's up with the chevy orange paint?
Old Oct 15, 2006 | 05:05 AM
Brandontyler65
I ♥ Acer
ya weld a socket or something that you can attach to an impact wrench and got on it a few times that will definently help also try to remove the crud built up betweet the bold and the block that is visble in the pic that just might be your problem
Old Oct 15, 2006 | 02:21 PM
mustanglover66's Avatar
mustanglover66
Here are a couple of torch setups you should consider one comes with the tanks ant the other you can get the tanks from a gas supplier with a deposit on the tank and just pay for the gas I think its cheaper this way.
http://www.northerntool.com/webapp/w...t_6970_565_565
http://www.northerntool.com/webapp/w...37356&R=137356
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
