Rattle can touch up
Old Oct 15, 2006 | 10:44 PM
palerider's Avatar
palerider
Default Rattle can touch up
The paint on my 1970 is oxford and is about a 5 to 10 footer. Does not look too bad . Starting to get some bubbling on paint on bottom doors - plus in corners of door looks like bondo PO put in has swelled - no rust breaking thru . Spots is below the crease on the door. I thought I can sand from crease down accross the length of the door and treat with POR 15 and rattle can prime and paint. Not ready to do full out paint - want to fix the cowl this winter and a few other basics first.
Just wanted to get some opinion on using rattles cans for this size touch ups. Apprecaite any advice. thanks
Old Oct 15, 2006 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rattle can touch up
For a small area like that, I see no problem using rattle can paint, if you put several light layers on so that when you are finished, it has a nice gloss to it and not an overspray look. The key is to match the old paint though. If you don't have a source for matching paint, I might suggest these guys. They will match the original color perfectly.
http://www.towerpaint.com
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Sep 30, 2015 12:39 PM
UrS4
Sep 30, 2015 10:13 AM
