squeeky belts
Old Oct 14, 2006 | 08:19 PM
duke's Avatar
duke
Default squeeky belts
My 66' coupe is running good but i can't seem to get my belts to stop squeeking. Any suggestions?
Old Oct 14, 2006 | 08:30 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: squeeky belts
Proper tension? New belts? Need pulleys? Accessory going bad and dragging too hard?
Old Oct 14, 2006 | 08:36 PM
duke's Avatar
duke
they are new belts, and correct tension, but what could be dragging too hard?
Old Oct 14, 2006 | 09:12 PM
duke's Avatar
duke
I think it may be my power steering pump. Do i need to get a new pump or just a new pulley
and if a new one is needed where should i get it
Old Oct 15, 2006 | 05:37 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
rub a bar of soap lightly on them
Old Oct 15, 2006 | 05:41 AM
Colorado_Mustang
Bad bearings in the alternator or power steering pump can cause the pump to drag and the belt to slip. Same with the water pump and its bushings. Whether you replace the pulley or the pump depends on the condition of the pump.
ORIGINAL: duke
Old Oct 15, 2006 | 10:00 PM
JBradley500's Avatar
JBradley500
try some belt dressing
Old Oct 15, 2006 | 11:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Belt dressing will work for awhile. Hell, even WD-40 will work for awhile. 99% of the time, the belt is not tight enough. The belt from the air con compressor or powersteering unit takes a lot of tension to keep it from squealing. There is also not much leverage we can use to get the alternator belt tight either. My bet would be the tension is not tight enough.
vargas
Jun 17, 2017 12:17 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
rafotree
Sep 22, 2015 03:55 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
