so umm... whats next?
Old Oct 23, 2006 | 12:57 AM
atomsk680's Avatar
atomsk680
Default RE: so umm... whats next?
ORIGINAL: Aussie66Fastback
working on your own car usually goes something like this...
Woman
1. Pull up to Jiffy Lube when the mileage reaches 3000 since
the last oil change.
2. Drink a cup of coffee.
3. 15 minutes later, write a check and leave with a properly
maintained vehicle.
Money Spent:
$20.00 Oil Change
$1.00 Coffee
$21.00 Total
Man:
1. Go to auto parts store and write a
check for $50 dollars for oil, filter, kitty litter, handcleaner and scented tree.
2. Discover that the used oil container is full. Instead of taking it back to recycle, dump in hole in back yard.
3. Open a beer and drink it.
4. Jack car up. Spend 30 minutes looking for jack stands.
5. Find jack stands under kid's pedal car.
6. In frustration, open another beer and drink it.
7. Place drain pan under engine.
8. Look for 9/16 box end wrench.
9. Give up and use crescent wrench.
10. Unscrew drain plug.
11. Drop drain plug in pan of hot oil; get hot oil on you in process.
12. Clean up.
13. Have another beer while oil is draining.
14. Look for oil filter wrench.
15. Give up; poke oil filter with screwdriver and twist it off.
16. Beer.
17. Buddy shows up; finish case with him. Finish oil change tomorrow.
18. Next day, drag pan full of old oil out from underneath car.
19. Throw kitty litter on oil spilled during step 18.
20. Beer. No, drank it all yesterday.
21. Walk to 7-11; buy beer.
22. Install new oil filter making sure to apply thin coat of clean oil to gasket first.
23. Dump first quart of fresh oil into engine.
24. Remember drain plug from step 11.
25. Hurry to replace drain plug before the whole quart of fresh oil drains onto floor.
26. Too late, remember drain plug now buried in back yard. Dig it up. Wash and replace.
27. Slip with wrench and bang knuckles on frame.
28. Bang head on floor board in reaction.
29. Begin cussing fit.
30. Throw wrench.
31. Cuss for additional 10 minutes because wrench hit Miss December (1992) in the left breast.
32. Clean up. Apply Band-Aid to knuckle.
33. Beer.
34. Beer.
35. Dump in additional 4 quarts of oil.
36. Beer.
37. Lower car from jack stands
38. Accidentally crush one of the jack stands
39. Move car back to apply more kitty litter to fresh oil spilled during step 23.
40. Test drive car
41. Get pulled over; arrested for driving under the influence.
42. Car gets impounded.
43. Make bail. Get car from impound yard.
Money Spent:
$50 parts
$12 beer
$75 replacement set of jack stands; hey the colors have to
match!
$1000 Bail
$200 Impound and towing fee
$1337 Total
BWAHAHAHAHAHA i was literally aughing out loud
Old Oct 23, 2006 | 01:23 AM
Sean W.'s Avatar
Sean W.
ya me to! especially the part where you hit your knuckels then hit your head in surprise. i did that yesterd except, i was taking out my headers, and i was unbolting one of the headers from the exhust and as i was lossening the last bolt, the header slipped ( was un bolted frome ngine ) and slid down and hit me in the chin, as it was falling i tired to move out of the way and wacked my head on the bottom of the transmission[:@]
Old Oct 23, 2006 | 02:47 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You'll want to make sure your rods/caps are marked as to their location. The order is 15263748 starting at the front of engine and going down the crank. During reassembly, you'll want the rods/caps back together, and it's a good idea to leave them where they left the block. Definitely balance the rotating assembly while it's apart. Your machine shop will help you here, but you'll need the crank, rods, pistons, rings, flywheel/flexplate, and damper at the machine shop for this step. The difference is worth the $100 or so for the work.
SapperDaddy21B
Feb 12, 2012 03:13 PM
nseoi
4 Cylinder NA and Turbo
Jul 21, 2008 09:09 AM
logicbombx
Wheels & Tires
Jul 1, 2008 11:15 PM
1nsanegt
Jan 28, 2008 05:11 PM
