70 rear window installation
Old Oct 27, 2006 | 01:12 PM
bigjeffscv's Avatar
bigjeffscv
Default 70 rear window installation
Hello to all, I just found this forum while trying to locate someone to install my rear window so that it will not leak. This has been an ongoing problem. Has been intalled 3 times with 3 new rubber seals and it still leaks. The last shop that did it must have used at least a full tube of black chaulk!! I am getting very frustrated by this. I would think that it would be an easy fix.
Any suggestions? I am in Santa Clarita, CA. and will drive a resonable distance to get this problem fixed.
Thanks
Jeff
Old Oct 31, 2006 | 09:00 PM
mach1muscle's Avatar
mach1muscle
Default RE: 70 rear window installation
Do it yourself. The trick is to use 3m bedding and glazing compound. It is a sealant that does not harded. It remains soft ad flexible to seal the window. I installed mine in about 15 minutes. Thought it would be a big hassle but it was easy.
Old Nov 1, 2006 | 12:50 PM
paddy187's Avatar
paddy187
i saw a trick on discovery show yesterday don't know if it will help, the guy put parachute cord in the rubber with a bit hanging down the placed the window with cord inside pulled the cord out which in the process seated the seal correctly around the body work
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
carid
Aug 25, 2015 08:17 AM
