pushrods
Old Nov 2, 2006 | 02:04 AM
atomsk680's Avatar
atomsk680
Default pushrods
ok, what is the difference between cromoly pushrods and normal steel rods? i got into an argument with a friend today about this and i just want to double check
Old Nov 2, 2006 | 03:05 AM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: pushrods
was this friend me by any chance?
Old Nov 2, 2006 | 03:08 AM
P Zero's Avatar
P Zero
Chromoly is an alloy, an alloy is a combination of metals (e.g.aluminum and iron) where as steel is just one metal (iron).
-P.
Old Nov 2, 2006 | 03:46 AM
atomsk680's Avatar
atomsk680
ORIGINAL: FuzzyDiceRule
no stop asking
[8D]
atomsk680's Avatar
atomsk680
ORIGINAL: P Zero
-P.
yea, so which is better for the engine, which ones is stronger, or more reliable.
Old Nov 2, 2006 | 12:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
which ever one u get, makes sure they are the ones that are one piece(dont have pressed or welded on ends) and u need hardened pushrods if ur running a setup the uses guide plates
Old Nov 3, 2006 | 02:43 PM
atomsk680's Avatar
atomsk680
quick question, i dont have guidplates, these pushrods i am looking say they are for a setup with guideplates. could i still use them or do i need to buy guideplates also?
Old Nov 3, 2006 | 05:49 PM
dodgestang's Avatar
dodgestang
Regular push rods will bend if something bad happens
Chrome moly will not
If you have guides you better be running chrome moly because regular pushrods will wear down
Better of the two....really depends on application....but chrome moly is the better choice for a performance application.
Old Nov 3, 2006 | 06:54 PM
atomsk680's Avatar
atomsk680
so other then guideplates and rods do i need anything else?
Old Nov 3, 2006 | 06:58 PM
P Zero's Avatar
P Zero
Whether you need them or not depends on your rocker. Boltdown fulcrum, no guideplate, screw in/press in stud - guide plate.
-P.
