Carburetor ID
Old Nov 5, 2006 | 08:26 PM
unit91's Avatar
unit91
Default Carburetor ID
I have a 69 stang with a 200 CI 6 cylinder. The carburetor blue tag says 1st line Motorcraft, 2nd line DOPF-K, 3rd line C-3F14. The body of the carb is stamped 1st line DOPF-95DK, 2nd line 4529-1-1603. What type carb is this? Carter, Ford, Motorcraft, Wal-Mart, ???? Thanks to anyone who can help.
Old Nov 5, 2006 | 08:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Carburetor ID
If it says Motorcraft, then that is what it is. That is what FOMOCO used. The I6's used the 1100 model Motorcraft on the 65-66 models, and most likely on that one as well.
Old Nov 5, 2006 | 08:33 PM
Yonco's Avatar
Yonco
duh! -Jon
Old Nov 5, 2006 | 08:50 PM
unit91's Avatar
unit91
Thanks......
Old Nov 5, 2006 | 08:51 PM
unit91's Avatar
unit91
Please excuse my ignorance........
Old Nov 5, 2006 | 09:48 PM
unit91's Avatar
unit91
OK. I checked diagrams for Autolite 1100, Motorcraft 1100, Ford F-1 and F-1100, Carters, and Holleys. My carb is none of those. Is there a place I can reference to decipher all those codes stamped on the thing? Thank you.
Old Nov 5, 2006 | 09:59 PM
85lebaront2's Avatar
85lebaront2
Post a picture of it, I can identify it for you. One question, does it appear to be 3 sections? If so, does the fuel inlet go into the top or center section? Top would probably be a Carter YF or YFA, center would be a Holley 1940. D0PF sounds like one of the Holley 1940 service carbs, These were also sold under the Motorcraft name. The D0PF is a service carb number.
Old Nov 5, 2006 | 10:03 PM
Cogtx's Avatar
Cogtx
Try this ebay link with some info on that model carb...might help...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8029898665
Old Nov 5, 2006 | 10:09 PM
Cogtx's Avatar
Cogtx
According to this forum post, looks like a replacement part/carb....
http://www.fordsix.com/forum/viewtop...f5df31767c9eb2
Old Nov 5, 2006 | 10:11 PM
unit91's Avatar
unit91
Thanks for the reply. I have several photos but this site says even one photo is too large a file. Do you have annother email address I could use?
