289 Refresh!
Old Nov 10, 2006 | 06:59 PM
Fastrrr's Avatar
Fastrrr
Default 289 Refresh!
I bought my 1966 Convertible a couple of years ago and I am thinking about pulling the engine and having it completely stripped and rebuilt. It has several oil leaks and just does not have power I sure it once had. Does anyone have any advice on what I should or should not have done? Also estimates on the cost? I am able to remove and replace the engine myself but I would have a professional engine rebuilder do all the engine work. I have a v-8 289 and I want to keep it completely stock. Any advice would be much appreciated..
Old Nov 10, 2006 | 07:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 289 Refresh!
Contact all machine shops in your area to get an estimate. Depending on where you are located the price will vary drastically from place to place. A stock overhaul should not cost you more than about 16 hundred dollars unless you are in Kali. You could also do it yourself if you have some tools and a decent knowledge about engines.
http://www.shop.com/op/~Haynes_Ford_...1?sourceid=298
Old Nov 10, 2006 | 08:00 PM
Bulldog66's Avatar
Bulldog66
If you're doing the work yourself, just have a reputable machine shop do the block work. They could do the head work as well.
If you're not doing the work yourself then I highly recommend checking into a crate motor.
Old Nov 11, 2006 | 12:58 AM
19stang66's Avatar
19stang66
ORIGINAL: Fastrrr
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
Aug 21, 2015 12:58 PM
