Shock removal Q?
Old Nov 13, 2006 | 11:02 PM
baddog671's Avatar
baddog671
Default Shock removal Q?
I was bored a little bit ago so I figured I would go ahead and remove my old front shocks. I loosened the 2 top bolts on the shock tower and expected the "arm" to come up, yet it stayed down. I went ahead and unbolted that mounting plate below it(forget the name all a sudden), but its still there. Isnt it supposed to raise up like in the "How to install a export brace" FAQ sheet?
Also, I removed one of the nuts on the bottom end and it seemed the whole suspension "moved". I didnt see what happend very well since I wasnt looking up, but I just want to make sure its ok to remove the shock without compressing the spring, so it dont kill me...
Old Nov 13, 2006 | 11:45 PM
baddog671's Avatar
baddog671
Default RE: Shock removal Q?
noone?
Old Nov 14, 2006 | 12:11 AM
6mustang6's Avatar
6mustang6
There's three top bolts????? If the suspension is in good shape, you should be able to unbolt the top, and the bottom and pull it out the top. If the shock is old as hell, it might not move up.
Old Nov 14, 2006 | 12:18 AM
baddog671's Avatar
baddog671
Just thought something...car is on jackstands, so the suspension is loose. Could it be fully uncompressed and thats why its not coming up?
Yes, there are 2 bolts holding the shock down, and 3 bolts on the cap that the shock bolts too.
Old Nov 14, 2006 | 01:12 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Only gas charged shocks will automatically extend the shocks. My off-road shocks don't automatically extend even when new...the same can be said for my SPAX shocks on my '71.
Old Nov 14, 2006 | 04:56 AM
paddy187's Avatar
paddy187
Baddog just pull up on the shock after removing bolts and shock tower thing the shock then should rise, when i did mine this weekend i was told by haynes/chilton to have the jact stands under the lower arms which i did with some wood for protection, could thatbe why your suspension moved?
Old Nov 14, 2006 | 04:02 PM
Lumbergh's Avatar
Lumbergh
I recently removed both of my front shocks with the car on the ground, no problem. The shocks didn't come up on there own at all, I had to grab the end and pull them out. IMO, jacking up the lower arms helps with the angle that you have to deal with when putting in the new ones but isn't a necessity. I could be wrong.
Old Nov 14, 2006 | 04:05 PM
paddy187's Avatar
paddy187
Lumbergh,
You could get at the lower perch bolts are did you just take of the front wheel?
Paddy
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
