frame damage
RE: frame damage
front.....frame piece that is parallel to sides of body on drivers side is sitting out about one-half inch from frame piece that goes from side to side. The same location on the passenger side does not look like that.
RE: frame damage
Short answer = yes. Pictures would be very helpful, however.
ORIGINAL: unit91
Is it possible for one section of frame to come un-welded from another? I've been driving around and just noticed that.
RE: frame damage
Unfortunately you can't just weld it up either. You have to measure the diaginals and make sure the car is still straight prior to welding it back together. Hence the reason for a frame shop, because if it is 'out' it will need to be pulled back into straight
