mach 1 question
Old Nov 28, 2006 | 12:17 AM
dcohen's Avatar
dcohen
Default mach 1 question
did 1972 mach 1's come fromthe factory with disc brakes? what about a rear sway bar?
Old Nov 28, 2006 | 09:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: mach 1 question
Don't know about the rear anti-sway bar, but the disc brakes up front were an option.
On edit: Seems like I remember that the 72 Mach had a performance package option, but didn't include the rear anti-sway bar. It would be easy enough to add one though.
Old Nov 28, 2006 | 07:52 PM
dcohen's Avatar
dcohen
well, im just trying to figure out what ive got, i bout this mustang for 400 bucks, its got a good running motor and an automatic transmission, the vin tage says its a 72 mach1 with a 302 2bbl, i dont think i lost anything on the deal, i figure the motor and tranny are worth 400
Old Nov 28, 2006 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
The 72 Mach had a low compression 302, so you didn't score a real hot engine. However, if you can use any of the parts from it to build another Mustang, then the money is well spent.
Old Nov 29, 2006 | 01:19 PM
jrrhd73must's Avatar
jrrhd73must
Only the 351C 4BBL and larger came with a rear sway bar. As far as the disc brakes go, I could not find a resource that said definiteively. I thought if it had a 351 or larger engine it came with disc brakes.
Old Nov 29, 2006 | 02:11 PM
72351CJ's Avatar
72351CJ
The rear disk brakes may have been added on at a later date by another owner.....
For more info on the 71-73 Mustang & mach-1's, check out:
http://ethiopie.50megs.com/MACH_ONES.html
Or here, this has alot of info on the 71-73 mustangs
http://429mustangcougarinfo.50megs.com/
Id fix it up or part it out depending on the amount of work needed to fix it up..
Or wanna really stand out in a crowd find one of these cult classics.
Or this one 1972 GT falcon xb
I cant understand were you find these cars for under 1000 bucks, but I do know the deals are out there... Whats the condition of the 72 mach1 for 400?
Old Nov 29, 2006 | 02:12 PM
eZ's Avatar
eZ
maN where do you people find these cars for 400$ i should move out into the sticks and buy some cars
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
