vin in the engine compartment
Old Dec 1, 2006 | 05:04 PM
supermanzx9r's Avatar
supermanzx9r
Default vin in the engine compartment
how do i decode the vin in the engine compartment
Old Dec 1, 2006 | 05:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: vin in the engine compartment
Use a decoder.
http://www.mustangdecoder.com/decoder.html
Old Dec 1, 2006 | 05:20 PM
supermanzx9r
that only does the data plate in the door jam
Old Dec 1, 2006 | 05:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Not true. The Warranty number is your VIN. Type in the warranty number where it has the block for the warranty number, and that will decode your VIN.
Old Dec 1, 2006 | 08:06 PM
supermanzx9r
but there are different numbers as well as the warranty numbers on the labal in the engine compartment
Old Dec 1, 2006 | 08:19 PM
paddy187's Avatar
paddy187
different numbers.... mean one is wrong what year is your stang? try removing the other fender there is a vin there, so it 2 out of the 3 match likely to be true
Old Dec 1, 2006 | 08:31 PM
supermanzx9r
the numbers match with both plates but there are other numbers on there also ...do you under stand what i am saying
Old Dec 1, 2006 | 08:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is a pic of my inner fender and the VIN that all DMV guys use to register your car. That is the number you type into the decoder in the Warranty block. Now, if you are talking about engine decoders then just say so. There are no other numbers on your inner fender other than the warranty/VIN.
[IMG]local://upfiles/10034/534CA37F222440AAB2093F381F7A819C.jpg[/IMG]
Old Dec 1, 2006 | 08:42 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the extra number tell some minor trim option like seat color etc stand or delux interior
Old Dec 1, 2006 | 08:53 PM
Hornblower's Avatar
Hornblower
I ♥ Acer
It sounds like you are new to the decoding process. The last several numbers only give you the unit number, which means what number your mustang came off the line. That is not so important unless you have a Shelby 428 CJ. Soaring is dead on about decoding your warranty number as being the same as the Vehicle Identification Number, and the number used by all Department of Motor Vehicles to register your car.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
tmdm
Sep 4, 2015 06:45 PM
