clutch help
Old Dec 7, 2006 | 04:17 AM
valley firearms's Avatar
valley firearms
Default clutch help
Will a 95 model year clutch work with a 60's model toploader? I don't know if the spline count and the shaft size are the same. I'm guessing no.
Old Dec 7, 2006 | 01:37 PM
gjz30075's Avatar
gjz30075
Default RE: clutch help
Any clutch will work with your toploader but the real questions are whether or not it'll bolt to your current flywheel because a '90s clutch may not be the same bolt pattern or size. Throwout bearing will be different. A 90's style clutch will most likely be a diaphram type and you would need to remove the underdash spring from the clutch pedal. If its from a modular motor, it may not have the same spline count but if from a 5.0, it probably will.
Old Dec 7, 2006 | 03:38 PM
Smothers's Avatar
Smothers
For what its worth, I have a 90's diaphram type clutch on my toploader. Not sure bout what exact year the clutch is.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
