Fuel & Brake Lines
Hey guys, just got done with the rear frame rails and the new leaf springs and gas tank have been installed now I want to run new gas and brake lines. Was wondering if anyone could give me an idea of the route they take, when i bought the car they were already gone, along with most everything else in the car.
I would imagine they run together down the drivers side, but how is the fuel line navigated through the rear end? I know it will come out by the frame rail and go through the fender apron but i'm not really sure how it should look. I have a manual but it really doesn't give a good look at it.
Also what diameter are the rear brake lines and fuel line?
Thanks guys
Thanks guys
Only two ways I can think of are
1 Try to find an Ford Shop Manual appropriate for the year. My recollection is that they cover the lines pretty well
2 Possibly you can find another car with an kindly owner who will let you get under with a camara and a note pad.
Obviously there are places where the steel gives way to flexible .
For example between the rear axle and the frame on the brakes and between the gas tank and the line and between the fuel pump and the line at the front.
Be warned--This will not be a quick job nor will it be fun. Brush up on your foul language skills you will be needing them
PS-If you don't have them buy the proper bending, cutting and fitting tools
ORIGINAL: DGA
My dad's buddy has a 66 mustang so it would probably be worth going over to that guys house and crawling under, see how they run.
For the front i bought the pre bent stainless lines and i ended up having to bend them all up to fit anyways so i figure whats the point in spending so much more for the pre bent lines... i plan on reusing my flex line off the rear axle for now. I just want to see this car roll so bad i am trying to just get everything together so i can go down the road with it. It'll be a site to see, open headers, no hood, no fenders, no trunk lid....... i'll make a movie and post it lol
And i do have the tools, it'd be near impossible to do without... i have put full brake lines on cars in the past but i just made them work and didnt care about looks.... i want these to atleast look close to what they are supposed to be.
Any idea on the diameter? looks like 5/16 but without a piece of one of the lines its hard to tell.
ORIGINAL: 69boss429
Very simple,call Classic Tube and get the exact parts for your car,all prebent with all attaching hardware.
