Getting a cam
Old Dec 12, 2006 | 05:23 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default Getting a cam
well i fig since i am getting heads i might aswell get a cam too but i have no clue what to look for al i know it that too much duration equals rough idle and short is dur is for blowers
but i am looking for a mostly mild cam with some lope in it
Old Dec 12, 2006 | 07:48 AM
w8less's Avatar
w8less
Default RE: Getting a cam
trick flow stg1
Old Dec 12, 2006 | 12:34 PM
THUMPIN455's Avatar
THUMPIN455
Brandon do you have a 289/302? I cant remember everything you have already. Do you have headers? What intake and head will you be using?
A mild cam like a Comp XE268 will give a moderate lope and a nice power increase. Just stay under 220 degrees duration at .050 lift and the cam will work great. Something in the range of 214-220 is what you are looking for.
The XE cams have faster opening lobe ramps, so they act a bit differently for the size compard to an old school style lobe.
Now if you have a larger head, like a Victor Jr or the AFRs over 200cc runners, then a bit more cam will be needed and complimentary. You will however need more stall and a bit more gear if you go with the larger heads and cam.
Old Dec 12, 2006 | 02:18 PM
Brandontyler65
I ♥ Acer
i am getting the world windsor jr heads (a sweet deal) i got a weiand i think its an stealth or an action plus not sure but i think they got same ports and an msd ignition and i got some headers also
Old Dec 12, 2006 | 03:29 PM
espskillz's Avatar
espskillz
yep im in the same boat as you im gona get some cams too my dads friend is a mechanic and said he would put them in for around 180 is that a good deal or no?
Old Dec 12, 2006 | 03:55 PM
espskillz's Avatar
espskillz
cams!!! http://www.mustangsplus.com/Merchant...e=eng_camshaft
Old Dec 12, 2006 | 04:10 PM
atomsk680's Avatar
atomsk680
summit is a good place to look for this kinda stuff
Old Dec 13, 2006 | 03:26 PM
Brandontyler65
I ♥ Acer
well i am looking at the ford racing cams and i have a question what firing order would be beter the 289 order or the 351 order i know that the 351 is supposedly better for the 1and5 cyl but how much better
Old Dec 13, 2006 | 08:38 PM
676869Stangs's Avatar
676869Stangs
I have a 302 with Windsor heads and picked up a Lunati cam/lifter kit from Summit. .223 duration at .50. Very good compared to the comp racing cam in there now. Hoping it will help me get better than 8mpg, but then I have to keep my foot out of it...HA
T
Old Dec 13, 2006 | 11:35 PM
farrellmotorsports's Avatar
farrellmotorsports
if you can i would recomennd a comp cams kit summit has one, i believe .218 duration with .456 lift cam, correct lifters timing chain and valve springs for 350$...if your going for a more streetable engine and not building just a monster a kit is very cost effective and imo the way to go...
