My stupid question of the minute
RE: My stupid question of the minute
My Mustang manual says to unbolt one side of the Transmission Oil Pan and let as much drain out as possible, then just take the pan off. Probably best to change the filter at that time as well. And replace the gasket. Sounds pretty messy.
thats right. it is extremely messy unbolt the pan and let it drain. defintely change the filter once you have the pan down and then fill it through the dipstick. good luck. its fairly simple just messy!
I know "where" it is, but you don't know what my engine bay looks like, I gotta find the danged this first, PO was insane!!!! Are there different kinds of ATF and if so what do you folks use?
ya the trick shift stuff is really nice however it sucks when u still have a stock c4 which requires 8 quarts (i think just off the top of my head) and at about $4 a quart it gets a bit pricy
Be very careful bolting that pan back on if you are using the cork gasket. If you don't tighten the bolts enough you get a drip and just a wee bit to much and you snap the gasket. Then you have tranny fluid all over the floor.
Trust me, I found out the hard way!!!!!!!!!!! (more than once)
