yet another suspension question....
Old Dec 15, 2006 | 05:45 PM
ford65stang's Avatar
ford65stang
Default yet another suspension question....
ok so i got the new engine and tranny.......and i oreded my power disc brakes and some koni shocks for the front......
what esle should i replace or get new parts for on the suspension......
I see how different kits out there.....do i really need to replace everything ?
then i see that there are sub frame connecters....should i get those too?
Old Dec 15, 2006 | 05:50 PM
baddog671's Avatar
baddog671
Default RE: yet another suspension question....
I got my rear and front suspension parts for 677 bucks, so it was well worth it. That is, with larger sway bars, KYB shocks, mideye leafs and 1" drop 620's, etc.
www.laurelmountainmustang.com ... its actually 749.00 but i deleted the steering
Old Dec 15, 2006 | 06:02 PM
grruminator78's Avatar
grruminator78
if you're going to replace some of it why not go ahead and replace all of those 40 year old suspension parts?? you may not need to replace it NOW but you will eventually, and do you really want to do the work twice?
Old Dec 15, 2006 | 06:44 PM
ford65stang
i dont want to do the work twice.....but if there's nothing wrong with it, why replace it....
i just dont know which parts are more prone to wear out.
Old Dec 15, 2006 | 06:49 PM
grruminator78
well you could start out with the grab-a-trak kits that cover the rear + new shocks + 620 coils + sway bars on both ends, and you'll have a new feeling ride plus a meaner stance, you can even pick the rear ride hight, I believe the 620s lower the front an inch. Then when you need to replace the front end stuff get that kit, then when you're steering starts to give, get the steering rebuild kit (unless you WANT R&P)..in the long run kits will save you money.
Old Dec 15, 2006 | 06:59 PM
eZ's Avatar
eZ
WAS THE CAR ORIGINALLY A 8 CYL.
Old Dec 15, 2006 | 07:05 PM
ford65stang
yep...it was a 289
ORIGINAL: eZ
Old Dec 15, 2006 | 07:06 PM
grruminator78
EZ looking at your avitar, did you have the back wheels up of the ground or what? [sm=badidea.gif][sm=joke.gif][sm=gears.gif]
Old Dec 15, 2006 | 07:14 PM
ford65stang
yea EZ...have you seen Ferris Bueller's Day Off
[IMG]local://upfiles/48851/6A56461967BE417B8B9EBA633466A0B7.gif[/IMG]
Old Dec 15, 2006 | 07:16 PM
grruminator78
I'm just sayin who has the time/balz to take a photo when doing 150+
