Brakes
Old Dec 20, 2006 | 08:13 AM
bl28ma's Avatar
bl28ma
Default Brakes
I want to convert my 66 from a single zone master cyl to a dual zone. I have the master cyl that I want to use. What other hardware do I need? Is there a valve that I need? And where would get it? Thanks
Old Dec 20, 2006 | 10:01 AM
bronco1's Avatar
bronco1
Default RE: Brakes
You'll probably need a new master cylinder push-rod, distribution block, proportioning valve, some steel line, fittings, and a tubing double-flare kit. Most of the Mustang parts houses like CJ Pony Parts, Laurel Mountain Mustang, etc... will have what you need. Good luck, it's not that difficult. Most of the front-disc conversion kits come with all you will need, might be a good time to make the jump...!
Old Dec 20, 2006 | 10:44 AM
paddy187's Avatar
paddy187
Default RE: Brakes
why don't they sell a kit for this seem like they have a kit for everthing else
Old Dec 20, 2006 | 11:31 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Brakes
It sounds like you are just changing from a single to a double MC and not necessarilly to a disc brake conversion. You will need a proportioning valve along with the new MC.
Old Dec 20, 2006 | 11:38 AM
bl28ma's Avatar
bl28ma
Default RE: Brakes
Can you help me out with the proportioning valve. Were it goes and how to set it up? No instructions....... Thanks
Old Dec 20, 2006 | 01:25 PM
Lumbergh's Avatar
Lumbergh
Default RE: Brakes
You need a repair manual. This sort of repair/replacement is probably covered in the basic Haynes/Chiltons repair manual (~$20)or you could get the Shop Manual (~$40) for your car.
Old Dec 20, 2006 | 03:07 PM
paddy187's Avatar
paddy187
Default RE: Brakes
http://www.va-mustang.com/articles.p...=11&page=5
Old Dec 20, 2006 | 03:08 PM
grruminator78's Avatar
grruminator78
Default RE: Brakes
This may help http://www.vintage-mustang.com/topic...rumtodisk.html
http://www.ford-trucks.com/article/i...ough_1964.html
http://s189516953.onlinehome.us/dual...cylinder.shtml
Good luck
Old Dec 20, 2006 | 03:38 PM
paddy187's Avatar
paddy187
Default RE: Brakes
grrum,
good find, on the last one http://www.kastang.net/dualmc.htmlworth of the FAQ Glen?
Old Dec 20, 2006 | 04:41 PM
grruminator78
Default RE: Brakes
the power of nothing to do + google makes me look smart once again
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
