Torque Specs
Old Dec 22, 2006 | 02:15 AM
68SCode4speed's Avatar
68SCode4speed
Default Torque Specs
Where do I find the torque specs for my mustang?? I have a large shop manual but I can't find the specs for the front end stuff. I'm doing the upper/lower arms, Shelby mod, tie rods, shocks, perches, spindles, converting to disc etc...
Where o where can I find the torque specs for all these items?
Old Dec 22, 2006 | 02:46 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Torque Specs
260, 289, 302
Fastener Type Torque Spec
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
351W
Fastener Type Torque Specs
Main cap bolts 95-105 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs.
Cylinder head bolts 90-100 ft.-lbs.
Harmonic damper bolt 70-90 ft.-lbs.
351C, 351M
Connecting rod bolts 40-45 ft.-lbs. (45-50 ft.-lbs. for Boss 351C)
Cylinder head bolts (follow factory torque sequence)105 ft.-lbs. (125 ft.-lbs. for Boss 351C)
Rocker arms (non-adjustable) 18-22 ft.-lbs.
5/16 in. intake manifold bolts 21-25 ft.-lbs.
3/8 in. intake manifold bolts 28-33 ft.-lbs.
Oil pump bolt 25 ft.-lbs.
Cam thrust plate bolts 9-12 ft.-lbs.
Front cover bolts 12-18 ft.-lbs.
429-460
Maincap bolts 95-105 ft.-lbs.
Cylinder head bolts 140 ft.-lbs.
Intake manifold bolts 25-30 ft.-lbs.
360, 390, 406, 427, 428 FE
Crossbolts for 406 and 427 40 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs. (53-58 ft.-lbs. for 406 and 427)
Cylinder head bolts 80-90 ft.-lbs. (100-110 ft.-lbs. for 1963-67 427)
Rocker arm shaft bolts 40-45 ft.-lbs.
Intake manifold bolts 32-35 ft.-lbs.
Oil pump bolt 12-15 ft.-lbs.
Old Dec 22, 2006 | 02:47 AM
Brandontyler65
I ♥ Acer
whoops wrong doc lemme find the other
Old Dec 22, 2006 | 10:57 AM
coda618's Avatar
coda618
If you have the actual FORD shop manual, torgue specs are listed at the end of each section. They have charts in a separte section than where the actual procedures are detailed.
Old Dec 22, 2006 | 11:45 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, my Haynes manual has the torque settings with each repair part. For instance, in the brake chapter, it has the settings listed at the end of the chapter. Get a manual cheap skate.
Old Dec 23, 2006 | 02:26 PM
JamesW's Avatar
JamesW
You can get the '65-66 shop manualon CD off ebay for 10-15 bucks.... or hardcopy for under 50.
Well worth it and a must have to work on these old cars.
Old Dec 24, 2006 | 01:48 AM
68SCode4speed
ah HA! At the END of the chapter... Actually I got ahead of myself and sped though the portion that showed that. Missed it. Thanks guys...
[IMG]local://upfiles/44155/BFC697AB83A541F98C6FA85AA666BA2A.jpg[/IMG]
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
LivingInThePast
Sep 16, 2015 12:20 PM
