Help me start my car
Old Dec 24, 2006 | 05:22 AM
gothand's Avatar
gothand
Default RE: Help me start my car
ORIGINAL: JamesW
Did you verify that the distributor was not installed 180 out?
You would still get a spark if the distributor were 180* off, it just wouldn't time properly for ignition.
Old Dec 24, 2006 | 05:35 AM
4reboy's Avatar
4reboy
Thanks everyone for the advice. I'm guessing it has to be a grounding issue of the coil because I'm 98% sure the connections are good (I even tightened the + and - tips and squeezed it on the coil studs). This is all becomming a PITA, but once we get it goin then its all worth it
Old Dec 24, 2006 | 12:29 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Make sure that you have a good engine ground, block to frame will work. That had me going for a few minutes after my rebuild. As soon as I put the ground strap on, WHAMO!!! Houston, we have liftoff. And for drivabilities sake, unless you are going for originality, find a Duraspark II setup and ditch the points
[IMG]local://upfiles/57088/69FA4875E85A430B9174585E24A13181.jpg[/IMG]
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
