Vacuum can. Where to mount?
Old Dec 28, 2006 | 09:28 AM
Ralph New Jersey's Avatar
Ralph New Jersey
Default Vacuum can. Where to mount?
70 Mach 1 351 C. Re-installing original A/C system. Can anyone tell me where the vacuum can gets mounted. The manual shows the passenger side, but does'nt tell you where. Under the right fender? Behind the firewall? Any help would be appreciated. Ralph
Old Dec 28, 2006 | 12:42 PM
Lumbergh's Avatar
Lumbergh
Default RE: Vacuum can. Where to mount?
I can't tell you for sure on yours, but on my 68, the vacuum canister is mounted under the fender outside the engine bay. The connections poke through the inner fender.
Old Dec 28, 2006 | 07:02 PM
Ralph New Jersey
Forward or to the rear of the shock tower?
Old Dec 28, 2006 | 07:33 PM
amchief's Avatar
amchief
Mine is mounted under the passenger side fender, attached to the firewall on the outside of the Apron.
I also have a 70 Mach1 that had a 351 in it.
Old Dec 28, 2006 | 07:38 PM
Lumbergh's Avatar
Lumbergh
Rear of the shock tower. Sounds like amcheif has the same set up on his 70 Mach 1.
Old Dec 29, 2006 | 08:54 PM
Ralph New Jersey
PS: Do I have to remove the fender to mount the vac can?
Old Dec 29, 2006 | 10:58 PM
amchief's Avatar
amchief
Would be easier, you may be able to do it with it on but i would remove it
Old Dec 30, 2006 | 02:53 AM
stanging's Avatar
stanging
If it mounts under the fender like on my 67', there will be a perforated or indentation spot where the factory would have put it. Just take a hole saw of the same size and cut it out. And it is behind the shock tower.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
