Door fix
Old Dec 30, 2006 | 04:35 AM
green_blurr's Avatar
green_blurr
Default Door fix
I patched some holes in my door with some sheet metal i cut out of a newer pontiac car my question is there are some holes in the metal where i did not fill in the patch itself is strong i put body filler over the weld and holes will the filler in the door eventually crack and break under the paint?
Old Jan 13, 2007 | 12:42 AM
mat11089's Avatar
mat11089
Default RE: Door fix
most likely it will u should of welded the holes or at least glasses them.keep your fingers crossed
Old Jan 13, 2007 | 01:22 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
grind it out and weld the metal up together, body filler will absorb water leading to rust(which was what ur trying to fix!) which in turn will cause it to crack
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
