C4 transmission pump
Old Dec 30, 2006 | 10:20 PM
eholzer07's Avatar
eholzer07
Default C4 transmission pump
So i got a c4 transmission built with a rebuilt torque convertor and have been trying to get it to work. I put it on the car and it would not go into gear. what i found is that my pump is not pumping any fluid. I have read that if you dont get the torque convertor in far enough(3 clicks)that it could ruin the pump. so i pulled the tranny off and i put it back together... It tooke me 3 clicks ( slide the convertor on, twist, slide on further, twist, slide on further) to get it on and i didnt have to force anything. Nor did i force anything the first time i put it on. So my question is where do i go from here... Where exactly is the pump in the tranny? And how could i tell if its the pump that is bad? ANY suggestions would be helpful. I am getting zero circulation of the fluid... I disconected the line between the transmission and the radiator to check it. and no fluid came out when the car was on and it was in gear.
PS Is therea differenc between how a 141 tooth c4 and a 157 tooth C4 is built besides the torque convertor and the bell housing?
Thanks
Eric
Old Dec 31, 2006 | 12:47 AM
middiepride's Avatar
middiepride
Default RE: C4 transmission pump
i think the difference in flywheels is the engine is what the tranny bolts up to.as for the fluid q, im gonna check back on this thread b/c i dont have the slightest idea. good luck
Old Dec 31, 2006 | 12:50 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
put it in reverse to circulate the fluid try that also did u fill the torque converter with fluid
Old Dec 31, 2006 | 01:34 AM
Colorado_Mustang's Avatar
Colorado_Mustang
The pump is in front, right behind the torque converter.
Old Dec 31, 2006 | 02:38 PM
eholzer07's Avatar
eholzer07
There is a cylindrical shaped part near the rear passenger side of the pan. It has electrical wires comeing from it. I dont no where to connect these wires. If these wires are disconnected could it cause the pump to not pump?? Also should i and could i remove to pump from the tranny. Could i be able to tell if the pump is bad??
THanks
Eric
Old Dec 31, 2006 | 03:52 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the c4 is non electronic they have no effect on the trans they are for the backup lights and neutral saftey switch
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
