starting problem
Old Jan 1, 2007 | 03:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: starting problem
just the diaphram is four screws try that out and get back on and lets us know
Old Jan 1, 2007 | 04:34 PM
Yonco's Avatar
Yonco
learn to say NO to your dad.... its helped me a lot! hah -Jon
Old Jan 1, 2007 | 04:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Stephen is probably right about the accelerator pump, but I would first check to see if you are getting gas TO the carburetor. Take the line off from the carb and turn the engine over with the line stuck in a jar, and see if you have good gas flow. If not, then suspect either a fuel filter or the fuel pump being bad.
Old Jan 1, 2007 | 06:29 PM
69stangcoupe's Avatar
69stangcoupe
i took a picture of something on my carb to show but the picture is too big how do you make it smaller to upload it?
Old Jan 1, 2007 | 06:37 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
download irfanveiw
Old Jan 1, 2007 | 06:43 PM
69stangcoupe
k i think i got it, ok do you see the piece on the front of the carb that looks like its supposed to be held down? is that right? Can someone post a pic of their carb and see what theirs looks like.
Old Jan 1, 2007 | 06:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
You can use Paint to downsize it.
Old Jan 1, 2007 | 06:47 PM
69stangcoupe
can you see it i posted it i think
Old Jan 1, 2007 | 06:49 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
thats it it has the little lever stickking out of it
Old Jan 1, 2007 | 06:52 PM
69stangcoupe
so how is it supposed to be?
