Bad Steering Box?
Old Jan 3, 2007 | 01:40 AM
fastsvo's Avatar
fastsvo
Default Bad Steering Box?
Hey guys,
What is the proper way to diagnose a loose/bad steering box? The car is currently on jack stands and right now I only have the pitman arm connected to the sector shaft - that's it.
I can turn the pitman arm by hand (not too hard to turn, not very easy to do so either) and I can feel a little bit of play somewhere in the radius of the steering box.
Should the pitman arm be really hard to turn by hand?
Thanks in advance,
Eric[/align]
Old Jan 3, 2007 | 04:09 AM
Incognegro's Avatar
Incognegro
Default RE: Bad Steering Box?
what exactly led u to the conclusion that its the steering box. it sounds to me anyways that it feels the way it should let me know what symptoms are
Old Jan 3, 2007 | 04:13 AM
Incognegro's Avatar
Incognegro
also i failed to mention. check the little u-joints in the steering shaft. if they are bad or worn at all. they could cause the steering to skip so to speak. hard spots while turning
Old Jan 3, 2007 | 12:59 PM
6mustang6's Avatar
6mustang6
What are these u-joints you are talking about? My dad's 67 power steering has alot of play in it, and it's very tight around curves, where it doesn't center, you have to turn the wheel to center it,.
Old Jan 4, 2007 | 03:07 PM
fastsvo's Avatar
fastsvo
Because there is a little amount of play as I move the pitman arm through it's range. I am in the process of basically rebuilding the entire PS system and so far have rebuilt the pump and power ram, with the control valve coming next. Now the question is my steering box next in line for a rebuild?
Old Jan 4, 2007 | 03:48 PM
highhilleer's Avatar
highhilleer
For your reading pleasure:
http://www.stangerssite.com/
search around a lot of really good information about the steering system
CS2007
Jun 25, 2019 09:45 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
