More Power?
Old Jan 4, 2007 | 05:08 PM
hondakilla's Avatar
hondakilla
Default More Power?
I just got my first mustang ever, a 1965 Mustang GT with a 302. It's got the factory four speed with a new racing clutch from Summit Racing, stock valves and headers. My parents think that it's fast enough already (and it is FAST) but I think it needs a little more power. Does anyone have any suggestions? Thanks.
Old Jan 4, 2007 | 05:42 PM
scott_m_mil's Avatar
scott_m_mil
Default RE: More Power?
Any idea on your current setup as far as intake/carb and rear gear ratio. These would be the easiest and quickest power pickups.
Old Jan 4, 2007 | 05:53 PM
sxs191's Avatar
sxs191
Love the nickname. An Underdrive pulley set up ($200.00) will give you a few more pony's and/or changing to an electric fan will too. Aftermarket headers are nice. These are things you can do before playing with the engine set up.
Old Jan 4, 2007 | 05:59 PM
sxs191's Avatar
sxs191
A Windage Tray will help also. Damn, I got to start putting some of this stuff on my car now that I think about it.
Old Jan 4, 2007 | 08:26 PM
atomsk680's Avatar
atomsk680
if you want alot of power, do a camshaft swap
Old Jan 4, 2007 | 09:35 PM
JamesW's Avatar
JamesW
To start with, I'd go through and give it a good tuning. Spark plugs, new wires, distributor cap and rotor. If it's got points, switch to a Pertronics electronic ignition module. Set timing. Simple and cheap. Then a new air filter, oil change, radiator fluid change and belts. Check air pressure in tires. Lubricate all the zerk fittings, even repack the front wheels.
After that I'd leave alone for at least 6 months to drive and get the feel of it.
Old Jan 4, 2007 | 10:02 PM
LCC's Avatar
LCC
Maximize the power you have and change the rear gear ratio to somthing a little taller...
Old Jan 4, 2007 | 10:04 PM
65mojoe's Avatar
65mojoe
Start with your exhaust (aftermarket LT's, new exhaust tubing, mufflers...etc..) and +1 to checking out what gear ratio you have in the thing. If it is decently fast now, swapping gears will make a noticeable difference for a minimal price. Exhaust will help it breathe a little better, and then from there, you can start to look into bigger power mods (I would stay away from cams and heads until you get a feel of the thing....theres a lot more you can do FIRST before you even touch the internals).
Old Jan 4, 2007 | 10:07 PM
Bulldog66's Avatar
Bulldog66
ORIGINAL: JamesW
Probably the best inifo for you.
Drive the thing and learn it's attitude. Get a feel of what she likes and dislikes.
This is like a girlfriend. Just take your time here and see if she's a keeper
Old Jan 4, 2007 | 10:40 PM
my77stang's Avatar
my77stang
on these older v belt cars cant some junk yard searching yield some good results for like 10 bucks? food for thought?!?!
if you wanna use stock springs i wouldnt go over .470 or so.... i had a summit 218/228 .471 cam in a otherwise stock 302 4bbl (stock valve springs) it had a nice idle and roasted the tires
+1,000 on that comment
unlike a any woman, a mustang is ALWAYS a keeper
