Cleaner?
Old Jan 4, 2007 | 06:10 PM
BakoLuke's Avatar
BakoLuke
Default Cleaner?
Does anyone know of a good block cleaner? I have an old 289 that needs a thourough cleaning.
Old Jan 4, 2007 | 06:18 PM
gothand's Avatar
gothand
Default RE: Cleaner?
For driveway type cleaning, I've had pretty good success with that foamy stuff from the autoparts store, followed with a scrub brush and a pressure washer (being careful with what the pressure washer is hitting).
Old Jan 4, 2007 | 06:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
I get a better cleaning with the oily degreaser as opposed to the foamy stuff. Take your car to a self-car wash and after you spray the degreaser on the warm engine, let it sit for about 10 minutes. Then hit it with the high pressure water on the soap cycle. Rinse off the soap, then see how clean it is. You may have to repeat the process, and maybe even use a wire brush to loosen the really thick crap. Follow that up with automotive grade Simple Green. That ought to do the trick. If the car won't start, don't sweat it. Just take the dizzy cap off and dry it with a clean dry cloth. Try not to wash the dizzy directly though.
Old Jan 4, 2007 | 06:26 PM
BakoLuke's Avatar
BakoLuke
ORIGINAL: Soaring
im going to do that with the '66 200. But the 289 motor is already taken out and the only thing i havent taken off are the heads and some other stuff. is there a better cleaner for a block thats out of the car?
Old Jan 4, 2007 | 09:58 PM
67Sally's Avatar
67Sally
ORIGINAL: BakoLuke
ORIGINAL: Soaring
If you cancover things up so it doesn't harm your block then just nailing it with a pressure washer will easily do the trick I would think. Rent one from a hardware store for like $50 and it will be spotless. If you go that route be sure to get a gas washer
Old Jan 4, 2007 | 10:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Hey, Flat Tire. Renting a high pressure washer for 50 bux would mean you want to wash your house. Silly kid.
Old Jan 4, 2007 | 10:15 PM
67Sally's Avatar
67Sally
ORIGINAL: Soaring
Well with the amount of time you'd save because there was no need for a wire brush or letting the degreaser sit you could probably hit a lot of the house if you need to. The $50 will get you 48 hours with it so I don't think cleaning up the garage or driveway in addition to the block is such a bad deal for $30 more than what you would have paid otherwise either.
Old Jan 4, 2007 | 10:56 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Brake cleaner + pressure washer = clean engine.
The engine degreaser foam stuff works if you have the patience to let it sit fora while.
Old Jan 4, 2007 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, but the problem with brake cleaner, is that it will get onto your paint, and you don't want that to happen, do you? Bad advice.
Old Jan 4, 2007 | 11:09 PM
Colorado_Mustang
He doesn't have the engine in the car....[&:]
