289 cid 1966
Old Jan 8, 2007 | 02:08 PM
arthur's Avatar
arthur
Default 289 cid 1966
can someone explain to me what the diffferences are between the 289 cid V8 between the 2V (200hp) and 4V (225hp) and Hi-Po 4V (271hp)
don't mean the hp but parts spec that goes in/on the engine
would it make difference when putting on a 289 2V a high performance alu intake manifold and headers ?
thank you
arthur
Old Jan 8, 2007 | 02:23 PM
paddy187's Avatar
paddy187
Default RE: 289 cid 1966
The 2v and 4v are about the carbs 2v having 2 venturi's and 4v having 4 this means that the intake for a 2v and 4v are different. The hi-po has different internals (there is a list in the FAQ's). The headers for 2v-4v are the same hipo had differentexhaust manifoldsthan stock to let the engine 'breath' better however aftermarket header will be the same no matter which 289 just make sure you get the correct ones i.e. manual vs auto
uberstang1
Dec 7, 2017 07:10 AM
GPR
Dec 16, 2015 12:21 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
