289 pics
Old Jan 9, 2007 | 10:40 AM
jrrhd73must's Avatar
jrrhd73must
Default 289 pics
Does anyone have any 289 pics they can post that show the power steering pump?
I would greatly appreciated it!
Old Jan 9, 2007 | 03:20 PM
UBY289's Avatar
UBY289
Default RE: 289 pics
This is a 289 from a 67 Coupe. I have since removed the pump and power steering. I like the manual steering alotbetter.Hope this helps you out.
[IMG]local://upfiles/32123/E3760642AC0E46F1B039CE93EDB79824.jpg[/IMG]
[IMG]local://upfiles/32123/4C2DCC39F8FC4EEBBF67D3262E778F1A.jpg[/IMG]
Old Jan 9, 2007 | 06:00 PM
jrrhd73must
Thanks!!
Old Jan 9, 2007 | 10:03 PM
gothand's Avatar
gothand
ORIGINAL: UBY289
Is that about a 10" air cleaner on there? Have you considered going to a 14"? You can get a reproduction Hi-Po type with element for a song.
Old Jan 10, 2007 | 11:23 AM
grruminator78's Avatar
grruminator78
at first I didn't even see an air cleaner!
Old Jan 10, 2007 | 01:36 PM
jrrhd73must
Is there a place thatI can get thatlong bolt that goes through the power steering pump? The one on the cougar I just bought is broken.
Old Jan 10, 2007 | 01:37 PM
67Sally's Avatar
67Sally
ORIGINAL: jrrhd73must
I found one at Home Depot...
Old Jan 10, 2007 | 01:59 PM
gothand's Avatar
gothand
ORIGINAL: 67Sally
IMO, Home Depot has just about the worst hardware department that I've ever seen considering how large the stores are. Their grade 5 & 8 as well as metric 8.8 stuff is pretty thin. I don't know if they have an Orchard Supply Hardware (OSH) near you, but they've got the best selection I've seen. Youcan get just about anything in high strength, either by piece or by bulk. I always go there for replacement grade 8 bolts and hardened washer for my beadlocks. [8D]
Old Jan 10, 2007 | 03:10 PM
grruminator78
In my experience mom and pop hardware stores usually have some good stuff.
Old Jan 10, 2007 | 03:35 PM
UBY289's Avatar
UBY289
Haven't really thought much about the size of the air filter,The car works fine with what is there, do you think it wouldlook or run better with the bigger Hi-Po one.
