Liquid Sound Deadner
Old Jan 9, 2007 | 07:21 PM
jarrettdad's Avatar
jarrettdad
Default Liquid Sound Deadner
Anyone use anything like Lizzard Skin? Is there anything that may be cheaper that I'm not finding? I'd don't really want to buy the spray gun and then a compressor to run it, but I guess that if I have to I will.
Suggestions?
Old Jan 9, 2007 | 07:42 PM
deebo68's Avatar
deebo68
Default RE: Liquid Sound Deadner
Does it need to be liquid?
Dynomat is a popular sound deadener, an alternative to that is the much cheaper "peel & seal" which is actually a roofing material.
As far as liquid, you could also try some roll on bed liner, I have heard of others using it with good results.
Deebo
Also, a compressor is a good investment espicially if your doing a restoration.
Old Jan 9, 2007 | 08:04 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
3m body shultz help to rust proof and keep down orad noise i think a can of it is 27$ and then u need a gun to spray it with if u dont get a 3m gun then u can get one for about 15$
Old Jan 9, 2007 | 08:31 PM
67Sally's Avatar
67Sally
Like Deebo said, a compressor is probably something that you're going to need so might as well buy one. Here's a website I thought might help you out a little.
Old Jan 9, 2007 | 10:52 PM
baddog671's Avatar
baddog671
If you have the money, go ahead and buy a compressor. If this is going to be a full scale restoration, you will be glad you have it when you hit the bolt from hell. I have used the peel and seal stuff in the trunk of my 98 mustang and it was pretty good. Those models are noisy all over, but it was mostly to help the SPL of my sub. I plan on using Dynamat on my 67 when that time comes. I haven't read much on the lizard skin actually...
Old Jan 9, 2007 | 11:26 PM
shr's Avatar
shr
i ran into a guy that used it on the bottom of his chevelle and it looked nice and he said it did lower the interior noise.... he said it took about 2 buckets to do the car and that and the gun was like 350.00 shipped to his door. after seeing his car i thinking about useing it on mine, alittle expensive but he said it was worth it.
Old Jan 9, 2007 | 11:30 PM
baddog671's Avatar
baddog671
For that much you could do Dynamat and be much more effective...
Old Jan 9, 2007 | 11:42 PM
Shifty101Easy's Avatar
Shifty101Easy
ORIGINAL: rmodel65
what kind of a gun do you use to spray it? what one is $15?
Old Jan 9, 2007 | 11:45 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i dont know the brand i saw it in the ppg store the other day the 3m gun was about 80$[:'(] the gun just screws on to the cans
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
