Whatchmacallit????
Old Jan 11, 2007 | 05:44 PM
ZZmustang's Avatar
ZZmustang
Banned
Default RE: Whatchmacallit????
the wire goes to a Hot when key is on .
Go to pepboys .com look in the Help bens The parts like window cranks, Vacuum manifolds, and other stuff for old cars. there is a genaric, ah, never mind I'll go find it for ya.
first place I looked was JC whitney
[IMG]local://upfiles/58274/DDB366449E264269818DA2E51985864A.jpg[/IMG]
Old Jan 11, 2007 | 07:47 PM
sxs191's Avatar
sxs191
JC Whitney doesn't have my year and I searched the Pep Boys sight and came up blank... Guess I'm stuck with my Asbestos tube....
Old Jan 11, 2007 | 11:15 PM
palerider's Avatar
palerider
I put my own headers on my 302 70. I was a little nervous about the bolts too. Did basically what jes72 did - hit with pb blaster over a few day period. tapped the bolts after applying each time. Also, tip I got which I did was turn to tightend slightly before backing out. In any case no problems. Good luck.
Old Jan 11, 2007 | 11:20 PM
sxs191's Avatar
sxs191
Thanks for the info. I'm going to give it a try after 2-3 days of PB Blasting them.
Old Jan 11, 2007 | 11:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
You have to use a decent socket wrench, and not a chinese made piece of crap. Soak the bolts with PB Blaster, then let them stand for a day or two. Soak them again with PB Blaster, and heat them with a butane torch. Let them set another few days. Hit them again with PB Blaster and the torch again, them after a few hours put your socket on the bolt and gently try to break it loose. Once it breaks loose from the bolt head to manifold, then you just rock the bolt back and forth; coming out a turn, then back in a turn, then back out another turn, use some more pb, then repeat the above process until the bolt is free from the block. Been there, done that.
