fuse removal
Old Jan 11, 2007 | 09:16 PM
cobramustangboy's Avatar
cobramustangboy
Default fuse removal
I have a 65 fastback and can't remove the darn fuses. Is there a special puller for inline fuses. One of them is only about an inch long, and I can't even get a finger in there to remove it. Any suggestions/recomendations welcomed, thanks!
Old Jan 11, 2007 | 09:20 PM
restomod66's Avatar
restomod66
Default RE: fuse removal
They sell fuse pullers at any parts store. Kinda looks like a tweezzer like object.
Old Jan 11, 2007 | 09:26 PM
restomod66's Avatar
restomod66
looks like this
Old Jan 11, 2007 | 09:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
I just use a small flat blade screwdriver and get one side to slide out, then use my fingers to pull it out. Been doing that for eons.
Old Jan 11, 2007 | 09:36 PM
gothand's Avatar
gothand
Are they rusted or melted in? First, if they are really stuck, I'd disco the battery so that you don't short/arc anything. Assuming the things are really stuck in there and the plastic puller or needle nosed plier don't work, take a very small flat blade screw driver and gently pry the metal retaining clip away from the body of the fuse just enough to break it free (be careful not to bend too far as to break it). Then, after breaking it free, use that little screwdriver and try to pry it out like Soaring said as close to the metal end to reduce the chance of breaking it. If that fails, break the sucker out and fish out the metal pieces with a screwdriver or pliers.
Old Jan 12, 2007 | 12:20 AM
6t9 stang's Avatar
6t9 stang
i just take some sort of flexible wire work it under the fuse and pull er' out.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
cbird1177711
Sep 2, 2015 04:12 PM
