Oiling Air Tools
Old Jan 13, 2007 | 11:03 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Oiling Air Tools
okay i dont really have much experience with air tools and was wondering how you oil the ones that dont have the little "oil" holes with a screw in it like my impact wrench...?
i have an oiler and air filter on the wall that i havent started using yet....do i just fill that thing with oil and let her rip? if i was to use it for spraying something does that get into the stuff being sprayed?
Old Jan 14, 2007 | 12:25 AM
dcohen's Avatar
dcohen
Default RE: Oiling Air Tools
I would just put a couple drops of oil down the air inlet coupling (where it hooks to the hose) every once in a while, you really dont need much
as for the painting question, you dont want to use the oiler with a spray gum because it will get in the paint and you will have a mess my friend
Old Jan 14, 2007 | 01:40 AM
Halz5's Avatar
Halz5
Maybe I am lucky but i have had my compressor and air tools for 7-8 years. I use them almost everyday and have never oiled them...
Old Jan 14, 2007 | 01:43 AM
andrewmp6's Avatar
andrewmp6
i only oil mine once in 6 years just remember less is more too much it will blow out the exhaust of the tool leaving a oily mess
Old Jan 14, 2007 | 02:10 AM
deebo68's Avatar
deebo68
You oil via the inlet vents, just a few drops or it will blow out the exhaust all over you.
Old Jan 14, 2007 | 08:35 AM
Shifty101Easy
yeah.....i found that out the hard way today. oh well, lesson learned!
Old Jan 14, 2007 | 02:42 PM
Decurion's Avatar
Decurion
I give mine a few drops every day, RELIGIOUSLY. You wouldnt run your engine without oil, so why run your air tools without it? Granted air tools arent under quite the same load as an engine, but the same theory applies. Occasionally Ive had to borrow someone elses air tool of some kind, and if they dont oil it, I would oil it for them and it always worked better. This is especially true when there is a lot of water in the lines.
Old Jan 14, 2007 | 04:17 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I add a drop to the inlet everytime I use the tool.
Old Jan 14, 2007 | 04:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Colorado_Mustang
Same here. Straight 30 weight.
Old Jan 14, 2007 | 04:27 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
+1
my dad will flip a bisquit if i dont oil those tools, i understand though
J.casone400
Sep 12, 2015 10:01 PM
fastbackford351
Sep 12, 2015 09:42 AM
Jb145700
Sep 11, 2015 12:28 PM
kevsgt
Sep 9, 2015 06:20 AM
