Fuel Pump Maybe
Old Jan 18, 2007 | 12:06 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default Fuel Pump Maybe
so i am sure that you guys know i got moy engine running but i noticed today that my fuel filter which is new (its a clear plastic one) is now running a very little puddle on the bottom where as yesterday it was full to the top could this part of my problem
Old Jan 18, 2007 | 03:44 AM
longlive289s's Avatar
longlive289s
Default RE: Fuel Pump Maybe
k well ill try and answer since no one else is.
not sure what u mean by puddle. i know those clear plastic ones your talking about tho. so at the bottom of the filter is a puddle of gas and it use to just fill and run fine?
its a little work, i did it but u could put a little pressure regulator between the filter and the pump.....should run aroun 6psi
Old Jan 18, 2007 | 10:47 AM
Soaring's Avatar
Soaring
I ♥ Acer
If the car runs fine, don't sweat it.
Old Jan 18, 2007 | 01:33 PM
Brandontyler65
I ♥ Acer
the car idles great out of gear but in gear it shakes so bad
Old Jan 18, 2007 | 11:44 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The in gear problem is more likely related to the state of tune of the engine. Even my clear fuel filter looks empty with a high flow fuel pump. Don't run out of gas at 7k, though.
Old Jan 18, 2007 | 11:58 PM
Brandontyler65
I ♥ Acer
i know what it is its the valves
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
