Oil Overflow?
Old Jan 20, 2007 | 12:04 AM
Muphukka's Avatar
Muphukka
Default Oil Overflow?
I have a '66 with an after-market .351. I purchaed it with this. On the oil cap, there is a hose coming of of it. It goes to nowhere. Is this to just spit oil out if the pressure gets too high?
[IMG]local://upfiles/54936/389BA15D4C0C4D10B593127C360D88CB.jpg[/IMG]
Old Jan 20, 2007 | 12:19 AM
Muphukka's Avatar
Muphukka
Default RE: Oil Overflow?
Here is a pic of the engine.
edit Let me see if I can find a bigger one /edit
[IMG]local://upfiles/54936/240FA5B2DEE54ED1835C3E077D29B7F5.jpg[/IMG]
Old Jan 20, 2007 | 12:21 AM
mustanglover66's Avatar
mustanglover66
No that is not a pressure relief, in the late 70's cars had a vent hose like that that went to the air brether to recycle gases that build up inside engines. mostly a emissions thing aslong as you have a pvc vale on the other head you can get rid of that cap and get one that look more period correct.
Old Jan 20, 2007 | 12:25 AM
Muphukka's Avatar
Muphukka
So you are saying that it is supposed to be attached to something? I need to figure out what that is. Any hints in where I can find where it is supposed to be connected?
Old Jan 20, 2007 | 12:27 AM
mustanglover66
66 had no essions stuff on it you don't need it
Old Jan 20, 2007 | 03:34 AM
gothand's Avatar
gothand
ORIGINAL: mustanglover66
Um, my brother's '66 convertible made for DSO Los Angeles had the factory Thermactor smog setup.
Old Jan 20, 2007 | 04:20 AM
Muphukka's Avatar
Muphukka
So you are saying that there is going ot be no oil overspillage out of this hose?
What about jamming it with something?I keep on thinking that the pressure is going to eventually blow some oil over the top of my engine.
Here is a better pic of the engine.
[IMG]local://upfiles/54936/7479F24A11C741CFAB1743E734BBAAD6.jpg[/IMG]
Old Jan 20, 2007 | 11:15 AM
colostang's Avatar
colostang
Oil won't blow all over your block. The hose used to connect to the stock air cleaner that came on your 351. Now you have an aftermarket cleaner with no input for the hose. Don't worry about it, if you are worried about appearances purchase a filler cap that you like to look at to replace it.
Old Jan 20, 2007 | 08:03 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
+1 on colostang's comments. Just buy an aftermarket cap that does not have the fitting for the cap to air cleaner hose.
Old Jan 20, 2007 | 09:15 PM
az1966's Avatar
az1966
I've got a 66 and it's got 1st generation smog on it
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
