air fuel screw settings
Old Jan 20, 2007 | 07:23 AM
baxsom's Avatar
baxsom
Default air fuel screw settings
what is the shipped settings on both of the air fuel screws for edelbrock carbs (1405) to be exact
mine came different
left was 2 1/2 out right was 2 out
i just want an even place to start
thanks
Old Jan 20, 2007 | 08:09 AM
stangimgood's Avatar
stangimgood
Default RE: air fuel screw settings
set both at your choice....then install on engine..start...then screw one side in untill rpm's start to drop...then back out 3/4 turn....then do the other side the same way...
Old Jan 20, 2007 | 08:15 AM
ZZmustang's Avatar
ZZmustang
Banned
I have always started at 1 1/2 out from bottom. This seems to work best for me. and then adjust from there, I don't think there is a factory setting , except maybe , at least 2 turns off the bottom.
Nice looking carb.
Old Jan 20, 2007 | 09:49 AM
baxsom's Avatar
baxsom
cool thanks
intake swap went great
thanks to everyone that helped
and mustangsteve.com made it incredibly easy
old out
new in
carb on
the edelbrock ford throttle adapter smacked right into the brace for my ac pump so i took the stock metal rod
got out a die and threaded the end and bolted it to the edlebrock linkage
works great
good thing my kickdown is attached to the pedal
car started right up
floats are set a little high
its surging and i can see fuel dripping from the venturis while it is idling but that should be an easy fix
Old Jan 20, 2007 | 01:04 PM
restomod66's Avatar
restomod66
Go to the FAQ section and there is a link for edelbrock carbs. there are videos on adjusting and troubleshooting those type of carbs.
Old Jan 20, 2007 | 02:07 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
start at two the get the vac gauge and go fromthere
Old Jan 20, 2007 | 03:20 PM
Yonco's Avatar
Yonco
do you usualy go up or down when tuning those? and adjust one a 1/4 turn, then do the other a 1/4 turn, wait for a sec, then repeat? or do one fully, then the other fully? -Jon
Old Jan 20, 2007 | 04:15 PM
Brandontyler65
I ♥ Acer
i turn one open the throttle look and listen for a change then do the next
Old Jan 20, 2007 | 10:17 PM
baxsom's Avatar
baxsom
found the videos
i like vids
they make life easy for those of us that always seem to miss a step with written instructions
Old Jan 21, 2007 | 04:26 AM
groho's Avatar
groho
Baxsom, do we bother on asking what's on that video?[8D]
Get a vacuum gauge and connect it to manifold vacuum. As long as both screws are set the same: 1.5 turns, or 2 turns, your fine. Start the motor, insure its warm, and watch the vacuum gauge as you adj each screw individually. Adj each screw, noting the turns in or out, until you have max vacuum, and don't over turn the screw, stop at max vacuum. Both screws setting should be very close the the same when done.
Works every time. I'm guessing but stock vacuum should be 16 to 20 psi, give or take.
djbigskrilla
Sep 20, 2022 01:04 AM
SYNY5TER
Sep 2, 2015 01:35 AM
Sep 1, 2015 08:16 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
MXBT187
Aug 20, 2015 02:36 AM
