What is this plug for?
Old Jan 20, 2007 | 05:09 PM
Muphukka's Avatar
Muphukka
Default What is this plug for?
Please forgive me if I'm not using the proper terminology here, I am learning.
I have a '66 Mustang with an aftermarket .351 in it. If I stand directly in front of the vehicle, the oil cap is to the right. In the back, there is another plug. In the enclosed pic, you see the plug in the back on the right side of the engine. It has a hose connected to it and it is underneath and to the right of the air filter.
What is this for?
How should I watch it?
How should I care for it?
Should I worry about it popping out under high pressure?
[IMG]local://upfiles/54936/C5DFBCF7D57C476F99010F89EE040E25.jpg[/IMG]
Old Jan 20, 2007 | 06:16 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: What is this plug for?
can you photoshop an arrow or something??? the "back" of the engine isnt even visible in the pic...and if its rightu nder the air filter it would have nothing to do with the back of the engine...?
and when you say, plug...do u just mean like a wire is coming out of whatever it is?
Old Jan 20, 2007 | 06:34 PM
ZZmustang's Avatar
ZZmustang
Banned
Either a charcoal filter or a PCV . .
The charcoal filter canister goes to the carb vent bowl.
Your picture . Like shifty said, is not clear.
If the picture is what you meant then the hose is going to the PCV. (Positive crankcase ventilation valve) in the valve cover. But the oil filter is on the other side. This valve has a slight vacuum on it and clears gases built up in the crankcase threw the valve cover and puts them into the intake system to be cycled out the exhaust. Gases get to the crankcase via the gap in the piston rings.
Old engine technology is so nice.
Old Jan 20, 2007 | 06:37 PM
my77stang's Avatar
my77stang
yeah he means pcv valve.... if you can shake it and it rattles, your good.
it should be plumbed back into the air cleaner type of area, or you can replace it with a small filter.
hows that for detailed advice?
Old Jan 20, 2007 | 06:41 PM
Muphukka's Avatar
Muphukka
Yeah, not the back.
To the left in the picture. Right underneath the air filter. There is a plug right into the top of the valve cover. I needed to research the term.
Old Jan 20, 2007 | 07:45 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
In that picture, the hose coming from the back of the valve cover is the pcv valve. Thepcv hose goes into the back of the carb.
Old Jan 20, 2007 | 08:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: OhioMachIRunner69
Actually, it should go into the carb spacer, but at any rate the PCV valve and it's related hose are the beginnings of re-burning engine gases for air polution reasons. Back in the day, we just had a hose that came out of the valve cover and was routed to the bottom of the firewall. Now, whether or not if the PCV valve rattles or not, you need to change it every year which should be about every 3 oil changes if you drive your car. That is just a part of the maintenance schedule.
Old Jan 20, 2007 | 10:18 PM
mustanglover66's Avatar
mustanglover66
is this what you are talking about if it is, its the pvc valve
[IMG]local://upfiles/33399/66F4350A545B4797BC35C080F0966630.jpg[/IMG]
Old Jan 20, 2007 | 10:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: mustanglover66
Wrong. We get that white water pipe PVC mixed up all the time with the PCV (Positive crankcase ventilation) all the time.
Old Jan 21, 2007 | 12:57 AM
baddog671's Avatar
baddog671
What ever happend to using breather caps?
