Ground strap on '67 I6...does it exist?
Old Jan 21, 2007 | 01:03 PM
Cogtx's Avatar
Cogtx
Default Ground strap on '67 I6...does it exist?
I've looked thru the 67 shop manual and wiring diagrams but can't seem to find any info on grounding strap for the I6. There is not one on my engine to firewall and wondering should one be there. I have sparks coming off the engine side connection of negative battery wire when starting the engine. Guess it could be a loose connction. Does anyone have pictures of where the grounding strap should be attached and also where the neg battery cable attaches to the engine..thanx guys!!!
Old Jan 21, 2007 | 02:28 PM
ZZmustang's Avatar
ZZmustang
Banned
Default RE: Ground strap on '67 I6...does it exist?
Old Jan 21, 2007 | 04:04 PM
65mojoe's Avatar
65mojoe
Hopefully this is a little bit more useful information than "selling it".
Unfortunately there aren't any diagrams in this tech article that show you where the strap goes, but in the 4th paragraph it explains that 1) the straps are essential to the system (hence youre sparking problem) and 2) they go in between the cylinder head and the firewall.
http://72.14.253.104/search?q=cache:...ient=firefox-a
Hope that helps a little bit.
Old Jan 21, 2007 | 04:29 PM
Cogtx's Avatar
Cogtx
Joe..thanx for the reply and link. You would think some type of grounding strap would be needed. However, the PO may have removed it for whatever reason. Can't seem to find any place to make the connections...I'll keep searching...
Old Jan 21, 2007 | 04:43 PM
65mojoe's Avatar
65mojoe
I just walked out to look at mine. I know yours will be different because its an I6, but my grounding strap is on the passenger side of the block and the firewall connection is just to the right of the blower motor for the heater; then the block connection point is on the backside of the passenger side cylinder head (counldn't see exactly where but I could feel it).
I would think as long as you have the thing touching the block and both connection points are solid grounds (good metal contact) then it should be doing its job.
Old Jan 21, 2007 | 08:36 PM
JamesW's Avatar
JamesW
It really doesn't matter where the grounding strap is, unless your trying to go for originality. The goal is to get an excellant ground between your block and your chassis.
Pick up a short starter cable at Autozone or such and find an unused threaded hole. If you can't find one, then one of the existing bolts that hold your accessories to the block. Whichever you find, make sure the surface area under the bolt head is perfectly clean and bare. Use a wire brush on a drill motor to clean the area thoroughly. Any other surfaces touching the cable should be wire brushed also. On the cable lug, take a file and rough up the surface a little, so that when you bolt it down, it will 'bite'. Now attach it in place, tightening down firmly. Attach the other end to a bolt that mounts into or on the frame. A good place up front is where the sway bar bushings mount to the angle frames. Use the same technique...perfectly clean.
You'll see a difference.
Old Jan 21, 2007 | 09:30 PM
Cogtx's Avatar
Cogtx
James...appreciate the reply and step-by-step. Went to Autozone today for a ground strap but they won't have any in till Wednesday. I will get on this soon and hopefully see some electrical gremlins disappear..
Old Jan 21, 2007 | 09:51 PM
JamesW's Avatar
JamesW
Here's a few pics I found that may help.
http://midnightdsigns.com/Mustang/Mo...unch%20009.jpg
This one runs from the framerail, along the firewall, to the back of the block.
http://midnightdsigns.com/Mustang/Mo...ater%20003.jpg
http://midnightdsigns.com/james/Fuel/Fuel5.jpg
Look under the bottom hose upper bend and you can see where this cable grounds to the block.
http://midnightdsigns.com/Mustang/He...ater%20004.jpg
Old Jan 25, 2007 | 02:35 AM
az1966's Avatar
az1966
I have a 66 I 6 the ground strap is going from the firewall by the blower motor to a valve cover bolt,,the neg for the battery is bolted to the block down by the alternater
Old Feb 12, 2007 | 11:41 PM
Cogtx's Avatar
Cogtx
OK...took everyones advice on this forum (and another) and connected the ground strap to the top starter bolt and then to the firewall....
Also, moved the negative ground battery cable to a stud/bolt on the block right above the water pump...
Thanx for y'alls help
[IMG]local://upfiles/19071/809D41C09F044F14A98609964DCC9398.jpg[/IMG]
[IMG]local://upfiles/19071/A01FD3F5724B4491915049C74E7DA3E4.jpg[/IMG]
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
uberstang1
Sep 21, 2015 09:04 AM
BrantleyS550
Sep 14, 2015 04:18 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
