amazing stuff
Old Jan 22, 2007 | 01:04 AM
my77stang's Avatar
my77stang
Default RE: amazing stuff
the first holley i owned came off a 351w e-150 van that had just been junked. it was the original carb, i bolted it on and drove away.
and yes, mathmatically a 600 is too big for a 289/302 but again, in reality your driving on the front two barrels 90% of the time so its flowing closer to 300 cfm.
really if you want it all there a good route to go would be a 500cfm 2 barrel. holley makes em, and i was once told the big block fords with 3 barrels were autolite 500cfm units. food for thought
Old Jan 22, 2007 | 01:57 AM
THUMPIN455's Avatar
THUMPIN455
Yonco try lowering the float levels. very easy to do with a holley. if you have a holley that wont run right, mail it to me and when you get it back it will work right...
Old Jan 22, 2007 | 04:49 AM
Lumbergh's Avatar
Lumbergh
Three different guys who are not on this board and whose opinions I respect told me that 450-500 cfm is the biggest flow you would want to go on a 289 with no mods other than intake and exhaust. So, that's what I'm planning on. I still need to decide between a Holley and Edelbrock, but I've got plenty of time before I get to that point, especially at the rate I'm moving on the car (sometimes I wonder ifI'm not movingbackwards).
Old Jan 22, 2007 | 05:03 AM
atomsk680's Avatar
atomsk680
edelbrock is nice, but i like holleys, i have a holley rband cam and intake, might as well go with a holley carb
Old Jan 22, 2007 | 06:46 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Lumbergh
Yeah, the 4100 is right at 480 cfm, so you would be right there with a 450-500.
Old Jan 22, 2007 | 03:22 PM
my77stang's Avatar
my77stang
i still disagree on the size even though mathmatically the numbers are low, look at some of the carbs ford used back in the day on small blocks.... hell wasnt shelby using 780's on some of em?
remember, unless every time you push on the gas pedal you are going WOT, or have a mechanical secondary double pumper - your only driving on the front two barrels and MAYBE when crusing the secondaries are slightly opened
if your gonna go small, http://www.holley.com/0-4412C.asp FTW
Old Jan 22, 2007 | 03:35 PM
deadcarnahans's Avatar
deadcarnahans
I agree. A 4V carb is just a small 2V until the secondaries flow. This is why they improve torque.
Holleys are dangerous leaking junk that should not be used on any car of value operated on the street.
There were no less than 12 of em in my shed that were set out by the street one morning.
The original postee would benifit from a new Edel carb or a rebuild of the old one.
Old Jan 22, 2007 | 05:52 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
i am thinkin of getting a demon with an adjust a jet kit
Old Jan 22, 2007 | 05:54 PM
my77stang's Avatar
my77stang
demons FTW!!!!!
Old Jan 22, 2007 | 06:02 PM
shr's Avatar
shr
+1 on the motorcraft carb!!! i have had a couple of edelbrocks and holleys they both have their ups and downs, but i do believe that holley is a better carb!
