I6 vibration driving me crazy!
Old Jan 22, 2007 | 08:14 PM
moondoggy's Avatar
moondoggy
Default I6 vibration driving me crazy!
Hello,
I've been lurking a while picking up good stuff, thanks to all.I have a 67 200ci daily driver I'm restoring and it has avibration from the engine which has slowly been getting worse. It is amplified under load (driveshaft may be contributing), but the problem is in every gear at a certain RPM range (I don't have a tach yet but its smack in the middle). IOW, start out no vibe, hits mid band - vibration. If I leave it in gear and push to higher RPM's it almost goes away. If I let it shift - same thing all over again. It is very similar to U-joint vibration and I replaced those before I noticed the RPM link. I've done a complete tune (points, plugs, condenser, wires, cap, rotor) and timed it. I also checked the compression, thinking maybe a bad valve - all 145psi+- 5psi. It comes as a "throb" with higher vibrations inside (dont know if I explained that right). Is there a test for the vibration damper?Any other suggestions will be greatly appreciated! Its a fun car that makes my commute tolerable. TIA
Old Jan 22, 2007 | 08:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: I6 vibration driving me crazy!
Obviously under load vibrations are caused by worn U joints that you say have been replaced, and rear end gears, plus of course the tranny itself. I would suspect the tranny before the rear.
Old Jan 22, 2007 | 10:37 PM
Mustang Boy's Avatar
Mustang Boy
i wouldnt suspect the rear cause of the RPM connections cause the rear doesnt change RPM's when the trans shifts so i would think its either somthing with the engine of trans
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
Golfsito
Oct 6, 2015 11:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
