Crossmember removal
Old Jan 24, 2007 | 01:59 PM
jcarden's Avatar
jcarden
Default Crossmember removal
I'm in the process of installing a complete new suspension kit. I got to removing the lower control arm on the passenger side and the bolt at the pivot point was installed from the backside. I cannot remove it as is because the crossmember is in the way. Can I simply drop the crossmember with the engine installed? If I do, are there any support requirements?
Old Jan 24, 2007 | 02:10 PM
eZ's Avatar
eZ
Default RE: Crossmember removal
yea i removed mine...do you have the car on jackstands at the frame?
Old Jan 24, 2007 | 05:45 PM
jcarden's Avatar
jcarden
No I'm using a giant floor jack for this repair. Using the frame as a life point on that side. Why?
Old Jan 24, 2007 | 06:37 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Pull it. It will be fine
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
wawagner82
Sep 13, 2015 09:02 AM
