new coil
Old Jan 28, 2007 | 05:52 PM
baxsom's Avatar
baxsom
Default new coil
if this has been covered before i apologize for not searching for the right key words
anyway
i am thinking about upgrading my stock coil to either a flame thrower or a blaster to go with the pertronix igntion inside my distributer
do i need to bypass the resistor wire and put a full 12v on the new coil or is the standard 6v wire going to work?
thanks,
Old Jan 28, 2007 | 06:24 PM
sxs191's Avatar
sxs191
Default RE: new coil
I put on a Pertronix Ignition on along with the Flamethrower coil and used the standard 6v wire, It is fine.
Old Jan 28, 2007 | 08:00 PM
baxsom's Avatar
baxsom
cool thanks
Old Jan 28, 2007 | 08:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yes, that way to hook it up will work as long as your volts don't fall below 7.5. The Pertronix module requires at least that much. I would really hate to be in Minnesota at this time of the year during a snow storm and the ignition voltage fell below 7.5. The sure fire way to assure you are getting 12 volts to the pertronix is to run a wire from your ignition and bypass the pink resistor wire. I have a how-to in the FAQ regarding this procedure.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
firehorse02
Nov 16, 2015 11:28 AM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
