please check my research
Old Jan 30, 2007 | 12:07 AM
baxsom's Avatar
baxsom
Default please check my research
Ok
so i have been reading all i can about about the GT40 head swap
and it seems like something i might want to try to tackle
but first id like to get confirmation on everything i read to cut down on time and money
i can get heads off of a 95-97 explorer 5.0, i thought i would go for 96 just to be safe
identifying marks will be GT stamped on the head and three casting marks
i can use my stock exhaust manifold and upgrade to hedders later with no fitment issues with the GT40s but the GT40Ps will require long tubes
GT40s will reduce compression and therfore horsepower unless you get them milled .030
i must by new 1.7 rockers to work with the heads. i read this but couldnt find much info about what else beside the roller rockers are needed
my stock valve covers will work
did i miss anything orget anything wrong
i checked theFAQand didnt see anything specific
a how to write up or a definitive stickywould be great
Old Jan 30, 2007 | 12:28 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: please check my research
can use the stock rocker arm off of the gt40s just need the correct pushrods for a rockers either pedstal(late model) or rail(vintage)
Old Jan 30, 2007 | 12:44 AM
baxsom's Avatar
baxsom
thats the part i dont understand yet
i have yet to find a post that tells absolutly everything I need to do the swap
heads, rockers, doo dads and tidbits
thats why a how to with pics would be great on this topic
its been asked about enough youd think someone would have made one already
Old Jan 30, 2007 | 12:57 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
bolt them, on get push rods for a non roller motor with pedestal rockers just call jegs and order a gasket kit and the pushrods it will bolt on
Old Jan 30, 2007 | 02:54 AM
DenDen's Avatar
DenDen
I tried the gt40p heads on my 70, 302 and had issues because of the plug angle.There is only one header that will fit and it didnt fit in the car.I modified a set of manifolds and had to make a spacer plate for the driver side.Put heat socks on the plug boots and still burned them.Had to change the valve springs as they were too strong from the factory and ate several pushrods before I figured it out.Its too bad I couldnt somehow make it work,they were great flowing heads that made good power even with the restrictive manifolds.I switched them out for aluminum ones.
Old Jan 30, 2007 | 05:43 PM
baxsom's Avatar
baxsom
you should have went with the standard gt40 heads
not the P
would have bolted right up apparently
jma2
Jul 10, 2023 01:00 AM
pimp2303
Sep 17, 2015 08:45 PM
BrantleyS550
Sep 14, 2015 04:18 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
