Play in Output Shaft
Old Jan 30, 2007 | 08:46 PM
unit91's Avatar
unit91
Default Play in Output Shaft
How much play should be in the output shaft of a C4 tranny? When I drop the drive shaft I can wiggle the output shaft a little. Is that normal or are my o-ring seals shot?
Old Jan 30, 2007 | 10:56 PM
Scott H.'s Avatar
Scott H.
Default RE: Play in Output Shaft
Old Jan 30, 2007 | 10:58 PM
gothand's Avatar
gothand
Do you mean wiggle up and down or you can turn the driveshaft back and forth slightly?
Old Jan 30, 2007 | 11:01 PM
P Zero's Avatar
P Zero
Up and down. Also look for a groove worn from where the bushing rides, if there is one youll need to replace the yoke.
-P.
bradleyb
Nov 27, 2015 07:50 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
breaking
Oct 2, 2015 01:27 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
cbird1177711
Sep 3, 2015 08:43 PM
