Blinker Trouble
Old Feb 2, 2007 | 02:26 AM
KS68STANG's Avatar
KS68STANG
Default Blinker Trouble
Once again another problem has occurred on my 68Coupe... i did find that the noise from my front suspension was just a little upper ball joint needing replaced. but on to greater matters, ever since i bought this car around christmas the blinkers only light up but will not blink. the hazards work. but the blinkers just stay soild. i ve replaced most of the bulbs and still... just a constant light. is my switch bad? or could the contacts just be dirty. because i did notice that if you mess with the hazard button the blinkers wont work. and the way my luck has been... i would imagine i have to replace the switch. if anyone has an idea let me know.. thanks fellas
Old Feb 2, 2007 | 02:37 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Blinker Trouble
you need a new flasher
Old Feb 2, 2007 | 02:38 AM
Brandontyler65
I ♥ Acer
and some blinker fluid might help too LMAO i had to go for it
Old Feb 2, 2007 | 12:15 PM
KS68STANG's Avatar
KS68STANG
ya bout that... wal mart is fresh out of blinker fluid maybe i just need to get spark plugs for a diesel while i m at it.
Old Feb 2, 2007 | 12:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
It could be several things. Take a read.
http://www.faqfarm.com/Q/Why_wouldn%..._flashers_work
Old Feb 2, 2007 | 01:19 PM
Brandontyler65
I ♥ Acer
ya muffler bearings might be bad too lets just hope its not your piston return springs aren't bad either
Old Feb 2, 2007 | 01:43 PM
NorCalTroy's Avatar
NorCalTroy
I have an extra flasher for my 1969 just hanging out in my garage looking for a new job, I'm not sure if they are the same or not, but if you do the research and send me a PM I'll drop it in the mail for you.
Edit: Second thought - not sure if, in-fact, the flasher is your problem. If the hazards work, I think the flasher should be fine. Maybe a bad ground? Maybe a bad blinker switch? Offer still stands if you want the flasher though.
Old Feb 2, 2007 | 03:09 PM
kalli's Avatar
kalli
ORIGINAL: NorCalTroy
had the same thought but wasn't sure on what the problem description was about.
KS68STANG: what's exactly the story with hazzard lights ?
do all 4 blinkers flsh when you put ion the hazzard ? if yes, then flasher can't be the problem.
if not, then what do you mean with "mess around with the hazzard" ?
kalli
Old Feb 2, 2007 | 03:12 PM
Brandontyler65
I ♥ Acer
i have two flashers in my mustang one for hazzard and one for turn
Old Feb 2, 2007 | 03:25 PM
kalli's Avatar
kalli
ORIGINAL: Brandontyler65
everyday I learn a new thing :-)
are they interchangeble to isolate the problem ?
Kalli
