68' suspension?
Old Feb 2, 2007 | 02:08 PM
deebo68's Avatar
deebo68
Default 68' suspension?
It seems to me that the suspension on the 67-68's are the same regardless of I6 or V8, is this an accurate statement?
If not what is different besides spindles?
Old Feb 2, 2007 | 02:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: 68' suspension?
umm i think that the v8 had beefier and more stout metal all about the suspension
Old Feb 2, 2007 | 04:46 PM
coda618's Avatar
coda618
Don't know about I6 cars, but on V8's the lower control arms are differenet on 67 and 68's.
Old Feb 2, 2007 | 05:19 PM
baddog671's Avatar
baddog671
Ive also wondered about this. I know when you do a I6-V8 conversion, you need to swap out the suspension, but I wondered what was different about it. Perhaps the springs are lower rated, but I would think the stamped metal parts would all be the same.
Old Feb 2, 2007 | 11:06 PM
67t5ponycoupe's Avatar
67t5ponycoupe
All parts the same from the spindles in.
Old Feb 3, 2007 | 12:06 AM
richmond20657's Avatar
richmond20657
Ditto alll the same
Old Feb 3, 2007 | 12:16 PM
deebo68's Avatar
deebo68
Thats what I was concluding since all the catalogs state a differance between 64-66 I6 vs V8 but do not distinguish between 67-68 I6 or V8.
If the spindles are the same then a disc brake conversion should be fairly simple. I guess the rearend would need to be modified or converted to 5 lug as well.
Old Feb 3, 2007 | 02:09 PM
deebo68's Avatar
deebo68
While we are on suspensions, I noticed this (see below) as I was doing some prep work for my suspension upgrade. I looks like a bad spot for rust, and maybe this car had a front fender bender as some point. The welds look like a poor repair, and the bend looks like someone hit something fairly hard.
Thanks,
Deebo
[IMG]local://upfiles/48783/99E0F247462B4882B140557DA6524469.jpg[/IMG]
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
